Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
  1. #11
    Apr 2009
    http://www.peninsulardiesel.com/WP-PENTEST/?page_id=216
    This just makes it way to easy it almost takes all the fun out of it I wonder how much they want for it.
  2. #12
    Apr 2009
  3. #13
    NW Houston
    Quote Originally Posted by SuperSaltAir View Post
    "attractive engine price" - "starting at $15,500" - yeah, right.
  4. #14
    May 2010
    Dixon, IL and Columbia, MO
    Wow Okie, I started reading through that thread and I was like wait a minute, why is he gelcoating it blue? I had found a different one, check this out
    http://forums.wakeboarder.com/viewtopic.php?t=84377
  5. #15
    Feb 2009
    Edmond, OK
    Oh yeah, I forgot about that orange one.
  6. #16
    NJ
    Note that a 6.9/7.3 has the same shape bellhousing as a 460, and they make 460 to velvet drive bellhousings. You'd just need to drill holes in the correct locations for the bolt pattern on the diesel. Not sure how a velvet drive would hold up to that the torque of a 7.3 turbo but you may be able to get some extra plates and discs in there.
    It can be done but likely all the little things to make it work will be expensive, don't expect to be saving money for at least a few years of frequent riding.
  7. #17
    Jul 2008
    Whidbey Island Washington
    Interesting build I like what that guys did with the diesel engine but after reading all of the posts I don't think he understands the concept of wakeboarding all that well yet.
    What I am thinking is a much bigger boat it has to be able to hold 10 people on top of that I want weight and I think I want 3k lbs not just 1k and I want to be able to go 25 mph all day long on 25 gal of fuel. I think a low hp extremely high torque motor would be best for that.
    Any diesel techs want to chime in?
    I also think going Chevy diesel will eliminate the problem with the adapter plates to the trany they should be the same as the 454's velvet drives
    GM manufacture deisel V-8's in th e1980's that were based on the gas 454 cid engine. This engine may not be the deisiel purests first choice, but it would mount up to the transmissions and exhaust risers that we are used to.
    GM now has a fantastic, large displacement v-8 deisel engine called the "Duramax" it uses for trucks. This engine is used in heavy equipment applications as well. It would probably work really well for your requirements, but I have no idea what risers, or transmissions it could interface with.
    Rick Ludtke
    1990 Supra Pirata
    1987 Supra Comp TS6M
  8. #18
    Apr 2009
    http://phoenix.craigslist.org/nph/cto/2444881581.html
    Looks like a suitable donor vehicle
  9. #19
    May 2011
    Niagara Falls, Ontario
    Now which V-Drive? What ratio, with all the torque available? How much extra weight will the new motor add?
  10. #20
    Mar 2010
    Windsor, Ontario
    Here is my pick for an engine.... Cummins will turn at 2500 rpm all day long and create almost too much tourque.....
    http://www.tadiesels.com/assets/docs/6BT59_220_spec.pdf
    If fuel is no option then this would be insane.....
    http://www.tadiesels.com/releases/Cu...ce%20Sheet.pdf
