84 supra comp w/ pcm 351
When running the boat on "fake a lake" it runs around 150 degrees and the risers are warm but never hot. I was out on the lake last weekend and the boat was running around 155-160 degrees and the riser would get hot. What could cause this? I did have some leaves and sticks in the oil cooler but I removed those and it still made no change. One more thing...After running the boat to temp and turning it off the tempature rises and everthing get hot, including the water pump(raw water). The temp guage will read 180 degrees, after starting the boat, it drops very quickly to 150 degrees or so. Is it normal for the engine temp to climb after being ran? Thanks guys. Enjoy the weekend.
