If there is no visual damage in the engine compartment, I would bet it's your damper plate. This happened to me last year. First some rattling, then total failure. The damper plate is attached to the flywheel and has a drive hub that engages the input shaft of your tranny. That is, unless yours is built different than mine. Fairly easy fix, but you better diagnose and get parts ordered if you want to be out Friday.
