Hey guys,
I have a 86 sunsport with a 351 and a velvet drive 71c. the trans took a dump on me july 4th...of course... I have a friend that is a mechanic and we took it apart ordered new clutches. Pump. Seals. And bearings. Put it back together and the boat would slip at 20mph. Called vince at skidid and he helped us trouble shoot. We put some seals in wrong I guess. We got itback together again and it work great for a hour then died again. Out of frustration and the fact that im moving to denver in a week I ordered a rebuit one that had been bench tested. Installed and again worked great for a hour then died....sequence of events : driving along at 3200rpm, noticed the engine was gettng hot. Stoped pulled the cover and all you could smell was burnt trans fluid. Drained and let cool added new and fluid. No change no forward reverse and no pressure when we pulled the reverse plug.
$2300 into it and I am still in the same position. Question - do you think the cooler killed me or a collapsed hose starving the trans causeing it to overheat? I am going to get a new cooler lines and take it to a shop.
Does anyone know a good shop in the denver area?
I feel sick to my stomach over this.....
