Originally Posted by
bens250ex
As long as it has the 7.3l your pretty much good to go. These engines are very reliable and pretty simple. The frames are all the same just different rear axles. Just be sure to check it out fully before you buy it. if the seller/dealer will let you take it to a reputable diesel shop/shop that has knowledge on diesels and let them run a couple test it would be in your best benefit. Check for abnormal Blowby, and run a injector test, check the trans and so forth can all be done on a good scanner. Also check the ball joints and other suspension parts. If you do get one with an automatic the first thing i would do is add a larger tranny cooler and a tranny temp gauge along with a egt gauge. Especially if you are towing. Then you can monitor the most important things. The automatic behind the 7.3l is the 4r100. Ford put a way way way to small tranny cooler on them and it causes them to overheat and burn the tranny up.
What year are you looking at? although they are all sim there are small differences between years. The biggest being in mid 01 they switched from forged rods to PMR rods.
Sounds like this thread has turned into the "ask a diesel expert" thread! What do you know about the 1988 7.3? I'm looking at a non-turbo version.
