Originally Posted by
suprasam
Sybrmike, Thanks. All internal hoses are good and dry, I am going to take apart the exhaust tonight and reseal with new sealant (3M). There is no way I can get to my rudder seal from the inside....can I ? I haven't looked closely, but the only place I am thinking I could get in would be by taking out the plastic/fiberglass rear compartment in the back, hell I don't even know how thats held in or if it can be taken out.
The exhausts are very likely leaking. Pull of the supratrapps and the mounting flange... Scrape out all of the old gasket material and use a wire brush to clean up the flanges. I even used a drill mounted wire brush to clean up the part of the transom that is beneath the flanges (be careful!) Use some new 3m 5200 or black RTV sealant and drill new holes for the flanges (you can reuse the old ones if they seem like they still have some "bite.") Mount the flanges and then remount the supratrapps. As soon as you get started you'll start to make sense of what all that means. Let us know if you have any questions... Should be a 2-3 beer job.
