I was woundering if anyone has installed new speakers in the stock tubes. I have a 21v and want to up grade the speakers and i like the light bar set up. help please
I was able to replace mine in the older style.
Krypt or kicker would be your HLCD options. Several high end coaxials likely fit as well.
I ran bullet coaxials first year and krypt hlcd's the second.
Fwiw, after going through this, I think its hard to duplicate the sound of speakers in there designed can with a can you put a speaker in.
Sent from my DROID RAZR using Tapatalk
2006 Supra 24SSV
i have installed it but i am confused how to use them so removed them from my boat
I added Wet Sounds 6.5 100 rms in my stock cans... I had to machine the face off and do some drilling... It sound pretty good but I then switched it all out for REV10s....
2011 242 Supra Launch
Stereo
Wet Sound 4 Rev10s on Tower
Wet Sound 8- 6 1/2 In Boat
2 Rockford 12" P3 Subs
Ballast Upgraded rear Bags 2 1100 lb
ACME 2079 prop
Shadow-Caster SCM-10 Under-Water LED
All Blue LED Interior Lights
