When it comes to polishing time is key. You are right about the wax build up, I think in the past someone waxed the boat to death and the sun baked in the wax. When I started last spring the whole boat looked like below the water line. For the best results use foam pads. Ones which have different cutting abilities. Some are for polishing and others for cutting. Any NAPA or Cross Canada will have them in stock. Also use the 3m polishes a sanding block and California water blade to squegee the fallout off the gel coat.
Still miss the ol boat too![]()
