This is just a wag if you are loosing comunication with the scan tool/code reader.
Unplug your sensors one at a time to see if it goes away.
Some ecms will shut down if a sensor is grounding the signal wire.Pp
Just had this happen on my jeep the crank sensor shorted out scanner would not read no cel flash on power up.
