Results 1 to 8 of 8
    Central Wisconsin
    Default Winterizing-Exhaust Manafold Plugs How to ?
    Hey all,
    summer seems long gone...
    Question?
    How do i get the plugs out of the Exhaust manafolds to drain the water? I know some do this and others do not, but i like to have all the bases covered.
    **see pic.
    Its this little square $*&%*^ that i can't seem to get out. i need the right tool for the right job but not sure what that would be.
    Others have had to run into this?
    Let me know. Thanks
    -Mike
    92 Supra Comp
    351 PCM
    Sep 2011
    Amherst, WI
    3/4 inch ratchet works. Might need a 3" extension. It is the same size as the square...no socket needed.
    Kevin
    1993 Supra Sunsport
    Sep 2011
    Amherst, WI
    BTW--have I asked where in central wi? I have a short memory!!
    I'm in Stevens Point...if you need any help let me know! Glad to help a fellow member.
    Kevin
    1993 Supra Sunsport
    Apr 2002
    Florence, AL
    Kevin's got you. 1/2" drive ratchet has got you covered.
    Don't forget there is a drain on each side of the block as well at at the bottom of the water pump elbow.
    1992 Supra Mariah - Red
    OJ XMP 4 Blade CNC 13x15.5RH
    Sep 2011
    Amherst, WI
    Quote Originally Posted by DKJBama92Mariah View Post
    Good call...1/2" not 3/4". Brain fart!
    Kevin
    1993 Supra Sunsport
    Mar 2010
    Windsor, Ontario
    You will be suprised on the debris wihich comes out of the manifolds. Beter to fart then to freeze.....
    Apr 2002
    Florence, AL
    Also, in case you didn't know. Pull the water hose off of the bottom of the transmission cooler and hold the end of the hose against the bottom of the bilge. This will drain the transmission cooler and the loop of hose that goes under the engine to the raw water pump.
    DKJ
    Sep 2011
    Amherst, WI
    Quote Originally Posted by DAFF View Post
    Agreed!
    Mike:
    Now that we figured out who we are ....let me know if you need any help with the winterization. Hopefully you have most of it done since it's been really cold overnight!
    Kevin
    1993 Supra Sunsport
