Page 27 of 30 FirstFirst ... 172526272829 ... LastLast
Results 261 to 270 of 297
  1. #261
    Nov 2011
    Paris, France
    Hi everyone !
    It's not finished, but I need your Pros and Cons. Here is my tower spot leds. There will be 2 of this thing on the tower.
    It's pretty easy, cheap and chic to build :
    Some plumbing stuff : ø50mm tube (can be free if you have spare in your garage), a connector to join 2 tubes, 1 rapid ø50mm clamp, and a openable ø63mm clamp. Then, I bought 12V DC 24 SMD Leds, Cool white color.
    Here is my 10$ spot :
    Stéphane
    1989 Supra Saltare
  2. #262
    Nov 2011
    Paris, France
    I will then paint everything in black. The rapid clamp will be glued to the 50mm tube.
    I would have put this under the tower, between the tower speaker box and the tower, but there is not enough space. So, it will be up of it.
    Leds seems sealed (opposit to the blue ones used in resin for the underwater spots), it is easy to change it, so I will test if it survives a rainy day ...
    Pros, cons, feeling ?
    Cheers
    Stéphane
    1989 Supra Saltare
  3. #263
    Sep 2010
    Collegedale, TN
    As with your other stuff, I think it looks great. Have you run the wiring yet? I didn't see it anywhere.
    1986 Saltare
  4. #264
    Nov 2011
    Paris, France
    Thanks Titan for your comment.
    No, it's not yet wired. I will do it the same way than the speaker box, with sealed connectors.
    Keep watching
    Stéphane
    1989 Supra Saltare
  5. #265
    Nov 2011
    Paris, France
    Hello guys !
    Finally the spot leds are finished. I didn't drill the top of my tower yet, I want to wait to see it on water by night before.
    it looks promising and powerful !!
    Give me your opinion :
    Stéphane
    1989 Supra Saltare
  6. #266
    Nov 2011
    Paris, France
    Stéphane
    1989 Supra Saltare
  7. #267
    Nov 2011
    Paris, France
    Boat clean and ready to go back in water :
    Back in water today :
    Stéphane
    1989 Supra Saltare
  8. #268
    Nov 2011
    Paris, France
    Home made marine led in water :
    It lights 2 meters behind the boat at 10:30 pm
    Comments are welcome
    Stéphane
    1989 Supra Saltare
  9. #269
    Sep 2004
    Hudson, WI
    I wanted to chime back in on the thermostat housing issue -- since the boat is back from Winter, I took a photo showing the housing. I'm fine running a regular automotive t-stat.
  10. #270
    Apr 2002
    Austin
    oh come one, wotan...you really wanted to show off your edelbrock performer intake. nice
    what's up with the wire at the bottom of the pic?
