Still needing some fine tuning but you can see I am holding the gate with my left hand. The hingeblock on top needs to be power planed down a bit.
With the hinges installed. I was getting tired so I didn't take any pictures of the individual hinges but they are inset into the gates for a more secure and compact fit.
This one shows the next angle I tried. Its about 22-30 degrees from the transom. It allowed for a lot better, peaked wake compared to my previous 40 degrees.
Side view with it retracted. The cut out for the rail has a piece that is mounted on a hinge from the backside that flips up and is held in place by a small piece of flat stock and a single screw.
