one place to check is on the engine and make sure that the bracket that hold the cable tight is still tight. I was hooking mine up tonight and the same thing happened... the clamp had come loose and all it was doing was moving the cable housing and not the cable itself.
there was not enough resistance to move the throttle so it just moved the cable.
86 Saltare
