Bilge pump on the Supras are found just forward of the ski pylon under the inspection cover. Here you will find a flapper switch and a pump. If you pull up on the flapper the pump should turn on. I would inspect the wiring looking for 12volts going to the flapper, if voltage is present the pump is more than likely stuck or worn out. Replacing it with new is cheap insurance for a fun day on the lake.
