Hello hello,
Does anybody know where to get a replacement bulb for the transom light on a '92 Comp? Is it a common bulb that I can get at my auto parts store?
Thanks!
Hello hello,
Thanks!
I went to superbright led's and got an led replacement...but you can get one at NAPA.
-Rich
Yup. Found on at Canadian Tire. Thanks.
Is that the dome above the tow hookup??? I have just purchased a 88 Comp TS6 and was wondering what that clear dome was for...
Quick question about the mast light, are both sides supposed to illuminate?
Yes and no... Allow me to explain. There are two light positions on your dash/panel/launch control whatever you wish to call it. The "Nav Light" switch should only illuminate the forward bulb on the mast, the transom light and the red/green lights as well. Now, the "Anchor Light" switch will illuminate the rear bulb of the mast as well as the forward bulb of the mast even if the "Nav Light" switch is in the off position. Clear as mud?
Clear thank you
