It's amazing how much a picture makes it look spectacularly reflective. Very slight imperfections can be seen in person, but not in the picture.
Yeah, I settled in on the following:
600 grit with a block, hand wetsanding fairly aggressively near the stripe...I'm working that area from the bottom of the blue to about 2" above the stripe.
Then I am using the air sander and wetsanding with 600-800-1000-1200. Typically, I'm using a light to medium pressure and letting the machine and disc do the work in about a 3-4' section until that disc is no longer cutting much. This also gives me a chance to switch to another task in the progression so the compressor can catch up. I only have a 2/6 hp 33 gallon compressor, so it has to work a bit to keep up with the sander.
I noticed some curly scratches when I compounded at this stage and didn't seem to have luck getting them out real easy with the air sander. I went back and tried it by hand with light pressure and found a method that seems to work, using 800-1000-2000.
Then the compound, polish and wax.
