Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 52
Thread: My 88 dilemma
  1. #41
    May 2013
    Default My 88 dilemma
    Looks great man!!
  2. #42
    Sep 2010
    Collegedale, TN
    Agreed. Looking good. Are you going to fill those holes in the motor mount area, or is it intended to be open?
    1986 Saltare
  3. #43
    kamloops, british colombia ,canada
    the bigger holes will be filled in with the same vent covers as the back of the boat , thats where my air intake from the front vents in, the smaller holes are for my steering cable and wireing harness on one side and battery on the other side
  4. #44
    Sep 2010
    Collegedale, TN
    Quote Originally Posted by 88pirata View Post
    Got it. I just hope you have great drainage for those areas because there'll could be water that high at some point
    1986 Saltare
  5. #45
    20130718_144932.jpgnew dog house ,made of aluminum20130718_144921.jpg20130719_203304.jpg20130719_203304.jpgputting tower on and hooking up speakers20130719_083815.jpgwhere I hope to be on sunday
    just the rub rail to go
  6. #46
    20130719_203241.jpgjust a front pic
  7. #47
    Sep 2010
    Collegedale, TN
    Looking great! I hope float day is a huge success.
    1986 Saltare
  8. #48
    All went well till we wanted to go home and the boat didnt want to start
    Luckily I didnt have rear seats screwed in yet as it was not getting any fuel
    Went to fuel filter, no fuel , checked fuel pick up tube and right at top a little steel bearing was blocking line
    so with a #2 Robinson screwdriver I knocked it out , reassembled fuel line , turned it over for abit and away we went20130810_170314.jpg
  9. #49
    Sep 2010
    Collegedale, TN
    It'll take a couple of shakedown cruises to get all the bugs worked out, but congrats for getting on the water again!
    1986 Saltare
  10. #50
    May 2013
    The steel ball is part of the anti siphon valve. When a boat sits for a while it is common for them to become sticky and stick shut. Pull the valve out and clean really good. It might be a good idea to have the tank cleaned out while your at it. Prolly have chunks of crud floating through your tank.
