Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 54
  1. #31
    Jul 2011
    Atlanta, GA
    I havent pulled a tube much the last couple of years. But when the kids were smaller and wanted to tube we had a big three person job that would suck a tank dry in a morning. The Tube makes A LOT of drag that will burn more fuel. Skiing, boarding, or even surfing will be much more efficient.
    1991 SunSport
  2. #32
    May 2006
    Nashville
    Looks like I'm in for a prop this year as well. Centerhill Lake was more debris than water this past weekend. I was doing badass dodging all weekend, then I caught a submerged floater and WHAM! The sound of the boat changed completely. I knew I had just dinged a blade.
    I've got 2 other stock spares I could put on, but I'm thinking I may want to invest in a newer style better prop.
  3. #33
    Dec 2012
    Clark, CO.
    I just ordered a new acme 913 yesterday. Delta prop had the lowest prices that i could find. I should have it by the 25th. This is a link to their site.
    http://www.deltaprop.com/boat-props/...rs-1-shaft.asp
    Function before fashion!
  4. #34
    Nov 2011
    Paris, France
    913 ACME ??? pitch is only 10 1/2 ! You will have a very low top end with that low pitch.
    Bill Weeks from ACME suggests me two props for the saltare, here were his words :
    "The picture does show that you have a LH propeller. That would mean that the Acme 1459-13.00X14.00VL3B 1.00 .135 cup three blade nibral propeller, would be a good choice. However if you want more power & less top end speed the Acme 431-13.00X13.00VL3B 1.00 .080 cup three blade nibral would be the prop of choice"
    Stéphane
    1989 Supra Saltare
  5. #35
    N.W. Suburbs Chicago, IL
    Yeah, but you have to take into account that he boats over a mile above sea level...whereas I boat around 700 feet above sea level which is a tad more than I bet you boat at. It's an apples to oranges comparison in that case.
  6. #36
    Apr 2002
    Austin
    interesting sdc77. when i bought my acme they recommended 541. i was running a fair amount of ballast back then, usually 1500 lbs.
    i know fuel consumption is an issue for you. do you use any ballast?
  7. #37
    Dec 2012
    Clark, CO.
    actually my lake is about 8200ft. With that being the case they recommended the 913. They did say the 541 and the 543 would make a noticable difference but if i wanted a big change then go with the 913. I surf almost exclusively and want the power to plane out even with 1500 ballast and 6 people. It's all about being able to pull stumps for me.
  8. #38
    Quote Originally Posted by 2500HD View Post
    I stand corrected then...almost a mile and half...my bad.
  9. #39
    Dec 2012
    Clark, CO.
    haha, didn't want to correct ya but at 3% hp loss per 1000ft it makes a big difference.
  10. #40
    May 2013
    Default New Prop arrived.
    I'm at 2600'. They recommended the 913 for me. Still have 40 mph top end, and it pulls out of the hole like a drag boat when empty. Definitely a great prop. This last weekend I had an Enzo sack, a 600, and a 450 full. Didn't even feel like it. Pulled through it like a champ!
    Sent from my iPhone using Tapatalk 2
