Originally Posted by
sfields
I bought my "dream boat" several years ago, a Ts6m like the one I had skiied behind when I was a kid. I immediately had the same heartbreak as many of you when I pulled the floor and found rot and waterlog. I pulled the floor, dug out the foam, spooned out the stringers, and started replacing. I recut the stringers from dry pressure treated 2x material, then took it to a local fiberglass guy who built boats for years at Norris Craft in La Follette, TN. He glassed them in beautifully, and had planned to put a floor in it for me later. A month or so later, he got sick... and never recovered. That was when my boat went on eternal hold. Now I have a garage that is plenty big for me to restart my project. Here are the issues from the past that worry me now:
1. I didn't "shore up" the hull when I pulled and replaced the stringers. I understand that this could have adversely affected the hull shape?
2. I didn't split the upper and lower hull... everything in the bow seemed solid, and I was worried that I couldn't put everything back correctly. The stringers were rotted from the drivers seat back, but I was cutting solid wood in front, so I reattached the new stringers to the new wood up front. Mistake?
3. I have some 1/2" marine plywood that I planned to floor with, and was depending on the "new" foam (that I haven't done yet) underneath to ad rigidity to it... after a couple hours of reading what you guys have shared, I'm not sure I want to foam it. I am now considering 3/4' pressure treated plywood without foam.
4. Since I didn't shore up the hull to replace stringers, and didn't replace the wood in the front of the boat, would foam add back rigidity and safety that I may need?
I hope that this boat will give a piece of my childhood to my two boys... but I don't want them to look back in 30 years at Dad's crazy renovation project that's sitting at the bottom of Norris Lake. If items 1 and 2 have sealed the boat's fate, then I will kill it now before going any further. Please share your opinions.
1) If you didn't pull the top cap, I suspect that the top cap kept everything together. The sides will separate from each other if not strapped or otherwise stabilized prior to cutting out the stringers, but with the top cap still on -- I believe that you're fine.
2) When I did my stringers, I did the same thing. I had good wood in the front of the boat and the stringers were solid. It was before I had found this board and before I had any sort of resource on how I should have tackled this. Everything in mine is solid and has been for years. If I had it to do over, I would replace all of the stringers but (oh dear god) I hope I never have that opportunity.
3) I used 3/4" marine plywood with the top and bottom both coated in fiberglass and CPES. I also added the foam (even though I originally planned to leave it out) because it did add significant support for the floor and quite a bit of sound deadening. My boat felt "live" before I added the foam back to it.
4) The only "safety" aspect of the foam is to meet coast guard standards that the boat must be able to float with a serious hull breach or while capsized. It's completely up to you but I couldn't imagine a scenario where the boat would be in half or upside down and I would be concerned with making sure it didn't sink. That's just me, though.
