Originally Posted by
Turbinesurgeon
Hmm, when it sits are you using the stereo or any other electricity? I noticed on mine if I’m using the stereo a lot and go to crank the engine spins at a normal speed but it doesn’t want to fire or it’s super slow to start. If I switch batteries then it fired right up. 06 isn’t know for vapor lock unless you have old watery gas in the tank. Check battery health. If it’s vapor lock then the next time it happens try starting at full throttle, without gear engaged of course.
