How is the wakeplate set? It makes a big difference.
Why the use of solid ballast? I would use water ballast. What does the tach run when you are running at 20-24MPH? If you have a 1:1 trans, they should in theory even out or at least be close. The "Multi use wake plate" is also crucial to helping your boat attitude when running.
The reason for solid ballast is sand bags are cheap... I only put 4 of them under the bow. I did man up and bought 2140lbs of fat sacs on thehouse.com for just $300 with pump included. The problem will be where to put them ha. I may even have to strap one 800lb bag to the front ontop of the bow, or remove the ghetto wood tanks someone made underneathe the closed bow if I can figure that out. One 800lb bag should easily lay accross the back, and hopefully the 540lb one can go on the drivers side bench. You know what, I don't think my boat has a WAKE PLATE... If it doesn't I can't imagine just drilling into the back of the boat, is it hard to install one? is it necessary? I'll take a look tonight, but i don't remember seeing a wakeplate.
Also I'll be honest, none of my gauges work ....... I use the phone for speedometer with an app. It's on my to do list though.
The wake plate is really important in helping the boat to plane out. Before you go do anything else to your boat, figure that out first. If it is not installed, the holes should all be back there still, just maybe filled in with a resin or something.
This thread is really something else. Wood ballast tanks? That tower?? No wake plate??
I need to just stay out......
you need to re-prop. you likely have the stock 13"x13 prop which doesn't like weight. go down to at least a 13"x11.5, but 10.5 if you plan on running 2000lbs on the regular. i have a 10.5 (Acme model 913) and can still do 34-35mph if needed (you lose some top end) but the extra grunt of the lower-pitched prop helps a ton. i run about 2500 lbs for surfing and it does well as long as i don't also have a full boat of people. if you have a big crew plus ballast, you may want to go with the 9-pitch surf prop that Acme has (model 2101).
I think I might just strap one of the 800lb sacks ontop of the homeade tower that has no reinforcement.
You're really giving me ideas. It'd be like a cable park, but pulling the kicker to me.
