Water pump won't prime!
I'm really at my wits end here. Boat is overheating and not pumping any (or not much) water. Here's what I've done:
Removed water pump and impeller, sealed everything well with RTV to make sure that their were no air leaks. Visually inspected the impeller -- no knicks, no broken fins.
Flushed both hoses that connect to the water pump. One of them had quite a bit of old impeller parts in it. Was sure that this was the issue but has not made a difference.
Removed thermostat and flushed thermostat housing.
Boat runs fine on a hose.... I'm assuming because this creates positive pressure on the supply side. Here's the tricky part -- when I run the supply into a bucket that is hose fed, it will create TONS of suction. But ONLY if the system has been primed with the hose before that. If I disconnect the supply and allow air to get into the system, the water pump will not develop any kind of suction.
With the garden hose connected there doesn't appear to be any leaks in any of the hoses. Hard to inspect the one that runs under the engine, but it seems fine?
I've had to be towed in 3-times this season because of this!
