Results 1 to 10 of 12
    Jul 2011
    Atlanta, GA
    Default Oh my! Boat flooded
    My boat is stored outdoors with an elaborate cover system that has worked well in the past. I still go out and check on it every month or so depending on what kind of weather we have had.
    I went out yesterday to check on her. I had not been out since Christmas and the cover structure had failed. At first I saw a big swimming pool of water collected in the middle or the tarp/cover and thought it would be ok because the water had been kept out of the boat and just collected in the big low place created by the weight of the water. After getting the water out of the tarp swimming pool I took the covers off and found to my horror that the drain hole had become clogged and that the boat had filled with water up to the floor and in the back (the boat is tipped up) over the floor by several inches!
    As I look for a warm dry place to get her dried out I'm trying to think of all the things that will have to be checked out. Everything that was removable was stored in the garage so seat cushions won't be a problem. The tranny was about 2/3 submerged so I'm guessing some water in there needs to be flushed out. The big question is how long was the water in there and how much managed to find its way into what piece of wood that has some small perferation in the glass. I'm trying not to have a cow about it but this is just not the way I wanted to start the new year. Any words of wisdom would be helpful. Wish me luck!
    1991 SunSport
    Dec 2012
    Clark, CO.
    I would think that just getting her good and dry would be all you really have to worry about. You could put a dehumidifier in for good measure though. Good luck.
    Apr 2002
    Austin
    that sucks. is your boat original or has it been rebuilt?
    you might try some damp rid buckets to help draw moisture out. you could also open some small access spots under the seats to see if you need to suck any water out. the wood should be able to handle a short dunking but long-term submersion will definitely be bad.
    Jul 2008
    Steamboat Springs, CO.
    Bummer to hear about your boat. I had a similar incident indoors with a roof leak, my boat was nosed down. I garaged it with the heat on and did use a dehumidifier. All is fine, that was three years ago. Good luck.
    Jul 2011
    Atlanta, GA
    Well this morning I drilled some holes in the stringers and found some spots of rot just between engine and exhaust. I have only had the boat for two years and have had so much great family time with it that what ever little problems I had were just small potatoes. Last spring while doing some work on the rudder and flappers I noticed some things like hollow sounding stringers and cracks in the glass around the stringers that made me understand that it was only a matter of time. So this morning after finding black goop in the stringer I was depressed but not suprised. My wife is a great gal. We had a heart to heart talk. The long and short of the matter is that she is making me take the boat to Donny's next week!
    I called Bennett boat repair a few minutes ago and he has one spot left to get a stringer job done by early April. Perfect timing I'd say.
    P.S. My wife is also insisting on having the interior redone. Life is just so hard some times
    1991 SunSport
    Mar 2011
    Charlotte, NC
    That SUCKS! This is exactly what happenned to mine and thus caused me to start a restoration on it! I ended having to rebuild the engine because water got in it through the oil pan. Also had to flush the transmission and of course the stringers were F ed
    "Where There's a Will, there's a way!"
    Check out my 1987 rebuild thread here
    https://forum.supraboats.com/showthr...-Resto-begins.
    Jul 2011
    Atlanta, GA
    I had in fact made an appointment this week end to have my back seat cushions done as a test. I havent had good luck with this in the past but this guy came highly recommended. He has done work for some folks on this board and I have seen some very nice things come out of his shop. The only thing that kept nagging at me about it was that If I needed the stringers done than I wanted the interior done after the cap came off. So here we go. First things first.
    Here is a question for those of you who have done this. My boat has maroon carpet that looks good with the maroon gel coat. I like the way it looks but don't like how hot it gets. It can be almost too hot to walk on after sitting a while in the sun. Donny says all the new boats come from the factory with tan or grey and that he has a hard time finding maroon. What have you all with maroon boats done with the carpet? I really like the way these boats came from the factory and don't want to change it up too much.
    1991 SunSport
