I put two in. I have a third made that I may add over the winter. I mounted them between the exhaust flaps and the mounts for te swim deck. Getting the wires up is a pita. I had to take the blower covers off and reach down to pull them up over the gas tank then feed them over the tank to the wire tube then hooked them to my kicker speakers that have LEDs built into them. The one thing that annoys me is that back factory light that is clear. Thinking about getting a blue bulb for that also. Does anyone know what type bulb goes in there. It's the one that's in the center of the transom. Comes on with the from nav light.
1995 supra labrisa
Pro boss gt40
GPS Ridesteady
It's a festoon bulb, just take it out and measure it in millimeters and that will correlate to a size on a website like www.superbrightleds.com
However, I would advise against changing that color. It's designed to be white as part of your navigation lights to signal that it's the rear of your craft. I think that changing it to blue would be quite frowned upon by any sheriff, coast guard or other law enforcement. I will probably change my white incandescent festoon bulb there to a WHITE led. But I won't be changing my rear white nav light color. Where I boat, we have Washington and Oregon law enforcement as well as US Coast Guard. Too much heat for me.
Yeah I'm on a small private lake that's 5 miles by two miles. Very few boats out at night and never any police. I was thinking rgb but I'm either going to pull the bulb, put a blue bulb in or an rgb that I can change from blue to white when I want.
1995 supra labrisa
Pro boss gt40
GPS Ridesteady
Nice replication Cusefan78. And kind comment on the DIY thing, thank you !
Hope you will enjoy your night excursions
I did replace my incandescent rear light with by a white led. As trayson said, I kept it white because of laws. Anyway if you stay on your private lake you can do what you want![]()
Stéphane
1989 Supra Saltare
Glad to read that my DIY underwater led is in minds.
That will be a good winter with many réplications
I also plan to add a 3rd led in the middle.
And maybe to work on a v2 of this concept with 3 high power Cree leds with directive 60° or 30° lens. The main difficulty with that idea will be to find the plastic holder in aluminium or stainless steal, acting as a heat exchanger for the HP leds.
Keep posting pics of your réplications guys![]()
Stéphane
1989 Supra Saltare
Cusefan78, did you use the resin you show on page 6 ?
Do you have pics of the leds after pouring ? Do you have bubbles ?
Need this informations to update my first post with a link for a good époxy resin in the USA.
Thanks![]()
Stéphane
1989 Supra Saltare
Yes I used that resin. No bubbles and they are crystal clear. I didn't take any pictures, wish I did. Been really busy with work. I bought the resin at micheals it was around $20 with the hardner.
1995 supra labrisa
Pro boss gt40
GPS Ridesteady
