I just cleaned the engine removed the manifolds and gave it 2-3 coats of high temp silver. I never intended to make a show boat if not for the oil leaks I would not have done it. I have a friend on the CC forum that specializes in reproducing the OE stickers on old Correct Crafts. Since the engines are the same so are the stickers. I have an extra set of the PCM and Tune up specs found on the valve covers cost is 12.00 for both.
