Originally Posted by
Chad Mueller
I searched some past threads and saw some mixed results with putting HLCD's into the Roswell cans. Wondering if there's any other info out there on that? I also saw that the Kicker 6.5 HLCD's are no longer available so Krypt is about the only option out there.
Was also wondering about the best way to swap out 2 of the existing speakers and replace them with the Krypts. Can I just wire them up as is or do I need to do some significant rewiring, swapping of amps, etc.? I've got the 2 amp setup that came as the factory option on my 2012 22 launch.
Or am I better off swapping all 4 towers for HLCD?
Chad
You could create a hybrid system but it would be a bitch to tune and you'll for sure want to wire each speaker off it's own amp channel so that you can even have a chance at it.
I'd replace all 4 with HLCDs. I'm partial to the Kicker system, but it's up to you. They don't make them anymore but that just means you can buy them cheap. Hurry -- $220 for this setup. http://www.sonicelectronix.com/item_...0KM6500.2.html
