Originally Posted by
padge
I actually called wet sounds and hooked it up just like he said. Still the same outcome. The wires from the unit itself are like 20ga. I just wonder if that has something to do with it. Or if I have a cheap aux cord. But when stereo on aux and my phone plugged in I have no interference
did you try grounding the RCA's inputs ? wrap a wire around the jack on the unit and then plug your RCA line into the jack .. this will help you diagnose what wire or speaker is not properly installed .. or just buy a noise suppressor
