Lookup how to align the propshaft. It should be done every couple of years. It takes about 30 mins with some feeler gauges. If its really out of whack, maybe an hour tops...
Also, dumb question but is the prop dine and dent free? The smallest ding can make a difference.
As for the leaks, small drips while underway are normal. When stopped it should not drip. I can't remember off the top of my head but somewhere around 1 drip every 5 to 10 seconds is normal. It's better to have more drips than less, as too little cooling on the packing glands will score the shaft and will require propshaft replacement.
The packing around the propshaft needs to be cooled by water when running. You can tighten the nut to slow the leakage. If its tight but youre still getting too much water in, replace the packing.
