Tracking fins have through bolts into the bilge, one pair goes through part of the pylon mount. Never heard of them leaking, but it's possible they could need to be cleaned up and resealed. The garboard plug for the drain plug could also be leaking. If you have Perfect Pass there may be a through hull for the paddlewheel which could have a leaky o-ring or less likely need the through hull fitting resealed.
