Did you have to get rid of the board rack? Mine are powder coated. All they are replacing is the swivel part correct?
08 24ssv Gravity Games
1200, 1100, and 750 Fly High Bags
6 Optima Blue Tops
Guest 10 Amp Charger
WS420
6 WetSounds Pro80s 10 xs650s
3 zx850.4 1 zx550.2 1 zx1000.1
Oil Drain Pump
Wow Fman, yours are much shinier than mine. When i bought the boat the racks had water spots all over them. I haven't had time to get out there and try to clean yet. But any recommendations on the best thing to clean them up with?
Yes, you will retain your stock board rack and Supra wing. It will replace the push button swivel and it comes with some different bolts as well. Call Scott at Roswell in the warranty department, they were on back order last year for 3 months! So you might want to call sooner than later.
White/Charcoal, 2011 VLX
2008 Supra 22SSV
Thanks for the info. Ill get the call made. It wasnt a real big problem. They tended to swivel 90 degrees when the boat was on the trailer goin down the road. I can only remember 1 time they did it on the water.
6 Optima Blue Tops
WS420
Oil Drain Pump
2008 Supra 22SSV
I went and got her out today. Getting her ready for her trip to Dallas tomorrow. Here is a pic of the updated truck as well. I worked on the truck more this winter than I did the boat.
6 Optima Blue Tops
WS420
Oil Drain Pump
Gravity - do you have a set of "Rock Tamers" for that beast?
I find that mine saves a lot of dings on the boat ...
Just got the new swivels put on. They are much better and there is NO play when they are locked in. That little rubber stopper is nice. I think these will be MUCH better this summer![]()
2005 Supra Launch 22 SSV
Semper Fidelis
