FMan, how much did your brass manifold cost you? Anyone have the PVC one from wakemakers and if so, any problems with it? Thanks for the help, hopefully these pics work.
I would just go with Wakemakers and save the money, I cant remember the cost but it was pretty expensive because of all the brass pieces.
I am getting ready to install a similar surf system in my VLX, I also found out wakemakers has changed up a couple items. You will need a one way check valve on the fill lines to the bags, apparently when the boat is driving it is sucking water out of the bags once water is filled in them. The water flowing under the boat creates a negative drag and pulls water out.
They are also not recommending using "vented loops" anymore. If you run the fill line up and over the rear compartment area (as high up as possible) you will not get any water in the bags when driving the boat.
They also are now selling the RULE 1100GPH tournament series ballast pump, which has a 3/4" NPT thread to 1" outlet. I am going with these pumps, they put out about 18GPM which is really good, you will fill a 750lb sac in about 5 minutes. Also going to use them for the drain pumps. I think they run about $50 a piece.
