Originally Posted by
Sdc77
Hi Ben,
No, it stumble coming off idle and doesn't want to do something else before it's warm. I tried smooth and rapid opening. Like too much something (fuel or air). But when it's warm, it runs perfect. Quick answer, good idle (500rpm) smooth and no vibration. I'll try do take a video next time I fire it.
I use unleaded 95 E10 fuel, as it's almost the only choice I have. Maybe it doesn't like it ?
95 ocatane is higher than I can even get here in the states so I doubt that is the culprit. Do me a favor, next time you have it out, open the dog house, take the air cleaner off and take a peak into the carb. Check to see if there is any fuel that is pooling in there. If so, time for a carb rebuild I would imagine. I would also check the plugs to make sure they are all clean. Video will help tremendously. Check out Cadunkle, he has a video of his Saltaire out on the water with a slight engine issue that he is talking about in the video.
