Page 9 of 16 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 153
  1. #81
    Mar 2011
    Charlotte, NC
    that is a cool video!!!
    "Where There's a Will, there's a way!"
    Check out my 1987 rebuild thread here
    https://forum.supraboats.com/showthr...-Resto-begins.
  2. #82
    Feb 2012
    Kingston, ON
    Quote Originally Posted by wspeedin View Post
    yeah its a regular wakeboard. These photos are actually of me riding Dean Smith's board which is the Ronix Mana. The cage is custom made to fit me perfectly and then it can mount to any wakeboard.
    Thanks man! I try to keep living my life no matter the obstacles put forth.
    No problem... I have very severe asthma... yes I realize it not the same deal.... however it's nearly killed me 3 times. I enjoy life despite having some limitations, and at least try even when others say I shouldn't or can't.
    Does your cage bolt on? or snaps to the edges? What board do you normally ride? I here the Mana is a sweet ride.
  3. #83
    Mar 2011
    Charlotte, NC
    severe asthma? and you are out there wet sanding that sunsport? man, you're crazy, lol. I dont think I would be out there sucking up fumes and dust if I had asthma, lol. but you gotta get it done, right.
    The cage bolts into the binding locations. This way you can move it forward or reverse to allow for a smooth ride. All last year I rode the 2011 Shaun Murray Nova Core board. The year before that i rode a cheap 2009? Gator Militant board. The Mana was a pretty neat board. It has an extremely late, aggresive, three stage rocker. Molded in fins at the tip and tail with a removable center fin. Also, the center is extremely flat so the landings are a bit rougher than the Murray board which has a center spine. The edge on the Mana allowed for quick and easy edging. Actually, I dont think I have ever edged that hard in my life. It is an aggresive board!!! And of course, seeing Dean Smith ride the baord you can understand why its like that. He goes so HUGE and so far into the flats! I know if it were me out there riding as big and hard as he does I would probably break some ligaments in the knees.
  4. #84
    Feb 2012
    Kingston, ON
    Hahaha! A man's gotta do what a man's gotta do. Ever tried an O'brien I love the Coda and I just got a Decade. Can't wait to try it... someday (sigh)
  5. #85
    London, Ontario, Canada
    Finally a pic of my tow pig and tow boat
    2009 21v Worlds 340 Cat
    Doug
  6. #86
    Oct 2007
    brighton, il
    We got out and rode last night only got two pics of the boat on the trailer.
    I would like to strip the rest of the decals of the side of the boat but my wife is mad i took of the Launch 21V We had the boat 5 years and i want to give it a new look.
  7. #87
    Sep 2011
    Amherst, WI
    Cell phone pic...sorry but I had to post our first session of the year. Couldn't pass up an 83* evening!!
    22mph, 60ft, no ballast, 2 adults combined weight of 250lbs (hey man, my wife only weighs 100lbs!), 2 kids combined weight of 70lbs. Got a couple w2w and 1 failed 360. Felt like a newbie out there after 4 years off!!
    Kevin
    1993 Supra Sunsport
  8. #88
    Sep 2004
    Hudson, WI
    Before.
    After.
    $300 via Craigslist!!
  9. #89
    Sep 2010
    Collegedale, TN
    For wheels AND tires?
    1986 Saltare
  10. #90
    Jul 2011
    Yay I finally get to join the post pics of boat in water!
    Finally got to wake board behind it for the first time. I was pretty happy with it.
