Quote Originally Posted by wspeedin View Post
you WILL need to strengthen your transom to mount a system like this. Both Mautique and Malibu's setups are only able to be installed on their newer built boats because they have restructured the transoms. You CANNOT install these setups on older models because of this reason.
Simple math...
It also seems like there's not a whole lot of pressure added onto the teak. There's a couple guys that bootyfabbed a setup over on the Malibu forum, where they have have the paddle clamped to the teak. One Mastercraft guy reported maybe 80-100kg of force on the paddle itself. Makes sense since 5psi = 20mph, 11 psi = 30mph, 19 psi = 40mph, 30 psi = 50mph (Taken from a Airguide Speedometer writeup). So We'll say that the PSI at 10mph is 3psi. A paddle that is 10X20 at a 45 degree angle will roughly have 100square inches of surface area, equaling 300lbs of force. They're not at a 45 degree angle, more like 20 degrees, so the force is probably somewhere around 150lbs. The teak and transom is more than capable of holding this
